I tried to do a search on this topic but the Search function doesn't want to cooperate??
Anyway, I lost turn signals and four ways the other day and am trying to troubleshoot. Fuses are fine. I then thought to replace the flasher unit, but was told that since the four ways and turn signals are on seperate circuits, that it was extremely doubtful that the problem would be the flasher and was much more likely to be the turn signal assembly.
I have the new signal assembly but need to know if you have to take off the steering wheel to replace? The concern is dealing with the airbag.... don't want to! Also, does the airbag absolutely have to be put back in, if worse comes to worse?
All input very appreciated! (This is a 91 Taurus GL)
Rachelle
Rachelle
