My left directional blinks very fast,I have no signal or brake light,left rear. I replaced the bulb,still doesn't work. The left front directional works fine. Is there a rear flasher for this vehicle ? I have no manual so I can't figure out what's what in the fuse box. The right side works fine. Thanks
QUOTE (the_intimidator_02 @ May 31 2010, 11:38 AM) index.php?act=findpost&pid=808108
One flasher control everything for normal turnsignals and one flasher for hazards. Did you check the bulb socket for corrosion? Is the bulb loose in the socket? you may have to check the wiring for a broken wire.[/b]
So it wouldn't be the flasher if all the other signal works.The bulb is tight but the socket is a little dirty.I'll have to get the wiring checked though it looks clean by eye
