1 - 13 of 13 Posts
What all would i need for this custom build? Anything would help.... 95 taurus.. im thinking at least 10 pounds... low boost.
There have to date, been no turbocharged TAURUSES, that were not SHO models. There have been a couple of turboed Probes, as well as a few turboed Rangers that have had the vulcan engine.
You might want to figure out what motor you have first since you don't have the Duratec.
The basics:
larger injectors
larger MAF
Chip/Tuning
Turbo
Piping
Intercooler is nice
Stick to around 6-8lbs to start
you can probably get away with out a tune at 6lbs
but you CANNOT get anywhere without a tranny build.
A lot of fab needed, but interestingly enough, there's a turbo kit claiming to be for a Vulcan, Duratec or SHO V6 engine, but if you read all the info, it states there is custom work required.
http://cgi.ebay.com/ebaymotors/_Car-Truck-...A1%7C240%3A1318
Mods: If this link violates the eBay posting rules, please remove it then. I am not the seller, just pointing it out for reference to some of the required work
A lot of fab needed, but interestingly enough, there's a turbo kit claiming to be for a Vulcan, Duratec or SHO V^ engine, but if you read all the info, it states there is custom work required.
Mods: If this link violates the ebAy posting rules, please remove it then. I am not the seller, just pointing it out for reference to some of the required work [/b]
That's an interesting start.
Its a start but its also a super generic kit. A lot of fab will be needed.
<div class='quotemain'>
Very true, not to mention the inferior quality of the kit. Only thing I might use out of that kit is the intercooler and piping.
There are a few hundred turbocharged 2Gen PGTs nowadays.
In the past few years a cheap set of turbo hotpipes hit the market for $300, that's really helped.
RyanPzz is also a PGT owner, having one of the big names in MegaSquirt really helped us get out of the dark ages of FMUs and needing a built motor even for 6-8#
I'm on my fourth.
I've assembled/built/modified/fixed a few dozen others.
10 pounds is not low boost for a former Naturally aspirated engine.
1 - 13 of 13 Posts
