1 - 9 of 9 Posts
well the bull is at the trans shop,going down the highway and she let go big time.
While it's being fixed, go buy a Magnafine in-line Transmission filter and have them install it in front (before) of the transmission cooler. This will help eliminate some of the metal debris that comes off the transmission. I slapped one on after my tranny flush and I have less hesitation and slipping since I've had it installed. I noticed the improvement almost instantly.
it depends if the case is ok i think the case is blown apart the way it exploded :ph34r:
What year? How many miles? Was the fluid clean?
My transmission feels awesome and it's always been cared for, I just want to know if I'm ok, or if I'm giving myself a false sense of security, I want it to last a long time.
G
If you know your tranny has always been cared for and fluid changed at regular intervals and you aren't too rough on it, it should last you a while. The only other preventative maintenance measure that is typically recommended is a tranny cooler so it runs at a cooler temperature, which will extend the life. If you do those things, the tranny *should* last you quite a while. :)
G
ouch, sorry to hear this Al. :( FWIW, I've seen new rebuild trannys for Taurii going on ebay pretty cheap in the past, you may want to check it out - could save you some $$$ if you need a new one. Best of luck with your repairs. :)
well i am a real sticker to maintenence and this was a experimental trans i changed fluid twice a year and i do have a very very large cooler
G
oh, that stuff was directed at 93 Sable. I figured you knew that stuff. ;)
1 - 9 of 9 Posts
