Hello,
My car will not go into gear, was working fine, pulled over for a fire truck to go by and hit some bumps and that was it. Now the 2003 tauras se will not even move.Does anyone have any suggestions?
With the engine running, how is the transmission fluid on the dip stick? If it's showing extremely overfull then you may have a pump failure. If fluid is normal then check the TRS sensor, would be my two guesses right now.
