1 - 15 of 15 Posts
Hello
Ive been having problems with a mystery transmission leak that I now believe is comming from the vent pipe as once agian when i pulled the transmission dip stick it had fluid all the way up it and it had a burp of fluid come out when i pulled it ....
so i pulled the vent off my ax4n transmission hoping to see a block and I didnt see a thing in that copper pipe...
now maybe I just didnt know how to Seat the black plastic cap or something but it was not blocked .....
my questions are:
1- after a ford dealer transmission flush (2000 miles ago) could they have put to much fluid in the system causing it to get rid of it ?
2- has anyone had a blocked vent that was visible .... or maybe the black cap has always been the issue ....
3- could there be something worse lurking in this transmission causing that issue ? It shifts fine no kicks or anything ......
Thank you see vent picture attached for fun
Move the plastic/rubber cap up and down. You will feel there are 2 positions. Keep it in the lifted position. Someone had a problem when the cap was pushed down.
cap
hmm ya maybe I didnt have it in the right spot
I do notice the two positions I think it was clicked into far but it still had movement .......
I wonder If i could just rig up a pvc pipe around the master cylinder like the TSB...
hello i posted last week about the same exact problem, on a taurus i recently purchased with 115,000 miles, i found the black cap on vent was completely pushed down. i reset the cap and so far so good im keeping fingers crossed. hope that is all it takes to fix your car.
taurus
Thanks Manny
did you push the black cap all the way down and this up one click? ? it seems to have a half way point...
Bring up an old thread. Working on a relative's 2002. Changed the fluid and it puked out about a quart in the driveway.Drivers side. Hmmm. From reading I inspected the transmission vent. No black cover on top just the brass fitting. The opening was clogged with grease. I cleaned it and ran a piece of coat hanger down it to make sure it was clear. Topped up the fluid and seems to be fine. When I change the oil next I will run the same piece of coat hanger into the vent to make sure it stays clear.
there is a fix for the vent issue... if you connect a hose and run it up around the master it will never have an issue again
My car has suddenly started leaving transmission fluid on the ground - and the stick is slightly out each time.
Mine still has the rubber cap, but was pressed down all the way. Assuming the vent is clear, is there any reason you couldn't just attach a rubber hose to the existing vent and route it as the TSB states? (to save the $20 :) )
Remove the rubber cap and throw it in the trash. I have 3 of these and none have a cap. When I change the oil I run a coat hangar down the vent to make sure it's clear. As mentioned here attach a rubber hose and clamp.
Exalted Grand Poobah
Where is this vent, if there is one at all on the ATX? Our old Tempo with the Vulcan does this. The transmission dipstick is always pushed off its seal and it leaves fluid in the driveway.
Thanks, I'll have to get a light and look for it. What's it look like?
1 - 15 of 15 Posts
