1 - 15 of 15 Posts
OK so I go out this afternoon to get ready to leave for work.
1. I turn my car on, starts perfectly, no problems at all.
2. I remove the parking brake.
3. I press on the brake pedal, and proceed to shift into D.
And then I notice that the shifter is very loose. I can pick the gear I want to be in, but the transmission stays in park. I tried to see if it would select any gear, and nothing. Not reverse or anything else either. I moved the shifter from park, and let go of the brake pedal, and the car is still not moving.
So what could this be? Some cable or something?
I let it warm up too, and I even disconnected the battery to reset the transmission, but nothing still. I checked the transmission fluid and it's still nice and red. I do need an oil change however, but it's only about 400 miles over. I have no clue what this is.
HELP PLEASE!
the shifter cable doesn't just break. (it's pretty thick. Check under the hood on the Transmission Range Ssensor (TRS) and make sure the cable didn't slip off.
Any pictures of that? I seriously don't know what anything is under the hood.
Also, brake lights DO come on, and I tried the whole set key to off and try shifting into neutral thing. And the shifter still does the same thing, very loose and doesn't CLUNK into neutral.
Nope, it won't move until I press the brake pedal in. Could it still be the interlock though?
I've seen 96s and 99s posted on here with having the shifter cable break with age...
If the shifter is very very loose, I would suspect that is your issue. You can manually shift the car by adjusting the above pictured metal bar.
Discussion Starter · #8 ·
Funny cause that's what I thought it maybe was. Does that move at all? Like when you shift would that move or something? I kind of looked at it, but it's dark out so I couldn't get a good look. I'll try tomorrow morning.
It's not too bad if I have to replace anything major, because I still have power train warranty on it. The only problem is that I can't even get it into neutral to get hooked up to a tow truck!
Moving it how exactly? If I can move it at the transmission then the transmission is probably good right?
With the hood popped have a friend move the shifter through all the positions while you watch the TRS. If the TRS at the transmission isn't moving, the shifter cable is broken. Use a pair of pliers and move it in the direction of the linkage. You should be able to feel the positions.
Discussion Starter · #10 ·
Yeah it's the cable. I went a step further to make sure it didn't come lose at the selector. Behind the steering wheel the cable moves, but at the TRS nothing at all.
Anybody got a thread that shows how to change the cable? Is it hard?
Discussion Starter · #12 ·
Make sure the cable is secured in fitting 2; it slides in and locks.
1 N801555-S58 Nut 2 7H181 Shift Actuator Cable Fitting 3 01605 Dash Panel 4 — Steering Column Lever (Part of 3C529) 5 7E395 Shift Cable 6 — Shift Cable Grommet (Part of 7E395) 7 7K499 Shift Cable Bracket 8 N804804-S100 Bolt 9 N803766-S56 Nut 10 7A256 Manual Control Lever A — Tighten to 20-26 Nm (15-19 Lb-Ft)
Discussion Starter · #14 ·
We are going to take it to a mechanic, but I'm going to make sure everything is nice and tight first. THANKS A LOT FOR THE PIC RDH2!
For the last 2 weeks of my tranny somewhat acting up it was the shift lever grommet that broke off.
1 - 15 of 15 Posts
