2002 ses 3.0 ohv, trans shifts normal at times other times it won't shift until high rpms. It's not consistent when it does this. I changed tps and didn't change it. Could it be vss sensor? Any input would be great.
2002 ses 3.0 ohv, trans shifts normal at times other times it won't shift until high rpms. It's not consistent when it does this. I changed tps and didn't change it. Visit AutoGuysLand to review why check engine light on but no codes if you concern. Could it be vss sensor? Any input would be great.
It could be low transmission fluid condition because there is a leak or contamination due to lack of maintenance or even water intrusion during off road or flooding conditions. Also, another cause is bad sensor. Then, i think you should start with transmission fluid. Good luck.
