TRANSMISSION TROUBLE
hello to all, I have a 1999 Taurus lx and the transmission will not go into reverse or drive. it happened in the same day to not work. so not knowing what to do, I unplugged a white colored electrical connection on top of the transmission. it was behind the battery and in front of the shift sensor or rather between the two of them, after that the car will go in reverse engaging slowly and in drive it go's just fine. I changed the v.s.s. but it did not make a difference. help! any suggestions? hope I don't need another transmission.:(
Our fords have a splined shaft that is concentric to the torque convertor. It has a common habit of getting stripped. You have no hydraulic pressure, since this stripped shaft powers the fluid pump within the trans.
Trans has to be pulled I am pretty sure.
A weakness in Ford design, so they say!
Welcome to TCCA! We all like pictures here so, snap a picture or two and post them here in the "Bull Stable"
Post a Picture of your Bull!
The search feature will be your friend around here as most topics/issues/modifications have been covered at some point, most times with the resolution to the issue.
Taurus Car Club of America : Ford Taurus Forum - Search Forums
The Topic Finder is VERY useful for LOTS of good information about our cars!
Ez Topic Finder
Please also check out these very useful topics about our forum:
Welcome To The Tcca!
How To Ask For Help
TCCA Staff Introduction Thread
And if you are interested in Submitting for the forum's Car of the Month (please view the rules first!)
Car Of The Month Submissions And Voting - Taurus Car Club of America : Ford Taurus Forum
Enjoy, and again welcome to the club :thumb: :tcca:
It might be electrical. in the fuse box in the front of the motor, look at fuse 28, if it is blown then thats where you start looking. that fuse it tied to trany shift soleniods, oxygen sensor heaters and more. I took the blown fuse out and hooked up my test light to the + battery terninal and the pointed part to the right side of the fuse socket. It was light so it proved there was ground. I started shaking things like o2 sensors and what ever else I could reach till the light went out.. that traced were the short was. fixed that and it's been running great since.
