I just bought a 98 Taurus and a couple days later it will not shift into what i'm guessing would be 4th. It runs up to 60 like normal and then will not shift. After doing a lot of searching I have found the tranny valve body is a common problem. I saw there was a write up in an older thread on the valve body, but it's missing the pictures. I just wanted to see if you guys think this is the problem or if it would be something else?
4th gear is overdrive, make sure that overdrive is on, also tell us if the OD light flashes
btw I have this problem too, my taurus overheats because she has to stay at 3rd gear at high revs
the forward control valve could be the problem
http://www.sonnax.com/system/announcement/96206-07K.pdf
http://www.v8sho.com/SHO/Valve%20Body%20Replacement.htm
http://www.sonnax.com/product-lines/transmission/parts/1260
http://www.transmissionpartsusa.com/AX4N_4F50N_forward_control_valve_p/400-09620607k.htm
I had the same problem in my 96 Wagon with the AX4N, it intermittently wouldn't shift into 4th and it threw a p0761 code. So, I pulled the valve body out, and replaced the 3 shift solenoids. (The p0761 code is for a solenoid c malfunction, which controls the 3-4 shift) My forward control valve retaining clip was not broken, but I installed the revised design clip while I had everything apart just to be on the safe side. I've put 3,000 miles on it since then and everything's been fine.
X2...I would also suggest putting the revised/upgraded clip in. When mine wouldn't shift into O/D..I had someone just install the revised clip. I have no more problems.
