121 - 126 of 126 Posts
Shh... I don't want that getting out and ruining my rep.
I should add that it's easier if you keep the black plastic air dam on the underside of the bumper cover with the cover; unbolt it from the radiator support instead. It's held on with 3 8mm bolts. I also don't disconnect the headlight wires from the bulbs; I just unbolt the housings and set them up on the radiator header panel still wired up.
I'm changing the ATF tomorrow (no cooler install.......yet). I was going to pull the splash guard under there....any tricks I should know about? (I haven't had a good look at it yet).
When I pulled the inner fender well sheets I stripped the plastic clips/rivets on them.
Dan suggests not doing a lot of the things I did. Having never done it before... I didn't know and just romoved pretty much everything.
Good luck.
I'll figure it out.
Well 2000SABLE, at least your honest about yourself there......I think your little title under your avatar says it all. Hey, why don't you post in that other thread where I was asking for ATF temps. Let me know whether or not you have a a temp gauge.
http://taurusclub.com/forum/index.php?show...mp;hl=ATF+temps
