The seal is what is on the tranny filter neck, don't know if that is the part the number refers to.
The flushing as described is from the Ford CD with a few modifications and is an approved Ford method.
Section 07-01B: Transaxle, Automatic—AX4N 1997 Taurus, Sable—3.0L (2V), 3.0L (4V), 3.4L SHO Workshop Manual
IN-VEHICLE SERVICE
Transaxle Fluid Drain and Refill
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number
Disconnect Tool T82L-9500-AH
Place the transaxle range selector lever in PARK and set the parking brake.
NOTE: The amount of fluid (fluid level) in the transaxle will affect the time it takes to drain the transaxle. Make sure to check the transaxle fluid level before proceeding.
Start engine and check transaxle fluid level. Refer to Check Fluid Level and Condition as described.
Turn engine off.
NOTE: If the vehicle is equipped with an air suspension system, the switch must be placed in the off position before raising the vehicle.
Raise and suitably support vehicle. Refer to Section 00-02 .
Remove the retainer clip from the lower transaxle fluid cooler tube and fitting.
NOTE: On vehicles equipped with 5/16 inch cooler lines, use Disconnect Tool T82L-9500-AH to disconnect the transaxle cooler tube. Place the tool on the cooler tube and push the tool into the cooler tube fitting. This action releases the plastic retaining tabs which holds the cooler in place. Then, pull the cooler tube from the transaxle cooler line fitting at the transaxle fluid cooler. On vehicle with 3/8 inch cooler tubes, pinch the plastic retaining tabs of the push connect fitting and pull the cooler tube to separate it from the cooler tube fitting.
Disconnect the lower transaxle cooler tube from the transaxle cooler tube fitting at the transaxle.
Attach a flexible hose approximately 0.9 meters (3.0 feet) in length to the end of the transaxle cooler tube and gently fasten the hose with a hose clamp.
Place the opposite end of the flexible hose into a suitable 14.2 liter (15 quart) container.
NOTE: When plugging the transaxle cooler tube fitting, make sure the plug is made of soft material to prevent damage to the internal seal of the cooler tube fitting.
Insert a plug into the transaxle cooler tube fitting at the transaxle to prevent any residual fluid leakage.
Lower vehicle.
NOTE: When the steady stream of transaxle fluid stops flowing the engine should be turned off to prevent damage to the transaxle. Engine rpm should not exceed curb idle speed while draining transaxle fluid.
Place the transaxle range selector lever in PARK and start the engine. Run the engine at idle while observing the flexible hose attached to the transaxle cooler tube. Run the engine at idle speed for approximately 40-60 seconds until the steady stream of transaxle fluid stops flowing. This step will drain approximately 1.9-2.8 liters (2-3 quarts).
Fill the transaxle with 9.5 liters (10 quarts of Motorcraft MERCON® (ATF) Transmission Fluid XT-2-QDX or equivalent meeting MERCON® specification.
NOTE: When the steady stream of fluid stops flowing the engine should be turned off to prevent damage to the transaxle. Engine rpm should not exceed curb idle speed while draining fluid.
Place the transaxle range selector lever in PARK and start the engine. Run the engine at idle while observing the flexible hose attached to the fluid cooler tube. Run the engine at idle speed for approximately 2-3 minutes until the steady stream of transmission fluid stops flowing. This step will drain approximately 9.5 liters (10 quarts).
Remove the plug from the transaxle cooler tube fitting at the transaxle.
Remove the flexible hose from the cooler tube.
NOTE: Carefully clean the cooler tube before installing it to ensure a good connection and to prevent fluid leaks.
Install the cooler line into the transaxle cooler fitting by pushing straight into the cooler tube fitting until a click is heard. Then, gently pull on the cooler tube to make sure the line is locked in place in the cooler tube fitting.
Install the retaining clip over the cooler tube and fitting.
Lower vehicle.
Add 1.9 liters (2 quarts) of Motorcraft MERCON® (ATF) Transmission Fluid XT-2-QDX or equivalent meeting MERCON® specification.
Place the transaxle range selector lever in park, apply the parking brake and start the engine. Move the transaxle range selector lever through all ranges allowing the transaxle to engage in each position and return transaxle range selector lever to PARK.
Check the transaxle fluid level. The fluid level at normal operating temperature should read within the crosshatched area of the fluid level indicator (7A020). If the fluid level reads below the crosshatched area of the fluid level indicator, adjust the fluid level by adding fluid in 0.2 liter (1/2 pint) increments until the correct fluid level is obtained.
