1 - 2 of 2 Posts
I want to check this out.Anyone have a pic of what I should be looking for?3 8mm bolts?
I took the tire off once and never did see the 3 bolts.
c clip?
CAUTION:
The servo cover is under spring tension. Care must be taken when removing.
NOTE:
Discard O-ring seal on cover.
7.Remove three 8mm overdrive servo cover bolts, cover, piston assembly and spring.
1 - 2 of 2 Posts
