1 - 2 of 2 Posts
OK its a 91 wagon, AXOD tranny, the lines going into and out of the transmission are leaking from the fittings at the case, should i just replace the fittings or is there more i need to do, btw im going to add a tranny cooler. Thanks
I would just add the trans cooler and change the fittings. It should fix the problem. If it doesn't replace the lines. They may be enlarged at the ends.
JR
1 - 2 of 2 Posts
