So my tranny is acting up, and it's not liking the power I'm putting through it. (Dyno test this Friday, fingers crossed, we'll see where I'm at). I'm going to put a better cooler in it, but I haven't decided between a G2 SHO cooler, or a Mr. Transmission one. If it's the Mr. Transmission one, I can get an employee discount and buy the giant one for the same price as the small one.
With that hopefully cooling the tranny, I was wondering if there was a way I could route some oil through the old tranny cooler. I mean, the only oil cooler we have is the wind passing under the oil pan, so what little cooling it provides would only be beneficial. Anyone have some ideas on where I could tap the lines?
As for the transmission, it has almost 190k on it. If it goes under for a full overhaul, I'll be up to $3000 for the rebuild. If I just take them the valve body, it will be much cheaper, but then my torque converter and clutch plates won't be looked at. Do you guys think that parts in the actual transmission need to be replaced right now, or would the valve body upgrades be plenty? (Assuming I do the whole both-transgo kit installs). Anything else I should consider?
