1 - 20 of 27 Posts
No, I bought it to replace a smaller Hayden I have now.
G
Any good write-ups about it? I don't seem to find any. I don't want to go at this small project without a idea where Im going to start. Note that I still haven't looked for the lines at all... so I may just be over reacting.
SableSal
Sablesal,
Dont get that piece of crap tube one.
Goto www.bulkpart.com
Look under hayden transmission coolers
get model # 1403? or smaller.
cost will be about 33 shipped
More cooling than you will ever need.
Installation is EZ.
-Damon
G
I happen to have two of those Hayden 1403's laying around (brand new). If you're interested, PM me. :)
I currently have a Hayden 1269 (1240) swirl-cool oil cooler and a Hayden 403 (1403) connected in series with my OEM chintzy tube cooler. I have the ATX cooler to the radiator disconnected. I am replacing the 403 with the 679. Don't say that it is more cooling than you need. Kind of like hard drive space or computer memory. :)
While traveling through the mountains and desert at +85 mph and when going up the grades my tranny temp still got up to ~245F with the above three coolers connected.
G
Discussion Starter #10
Originally posted by duratecchie@Jul 25 2004, 10:28 AM
Sablesal,
Installation is EZ.
-Damon
Thanks Damon,
And to all who have replied with suggestions. Im thinking Im going to go with a Hayden Tranny Cooler. Model? Not too sure yet. More suggestions would be awesome. Keep em coming! Also, installation... anyone have pics of the install in a GEN3? Let me know, thank you soo much
SableSal
Instead of starting a new post, I hope you don't mind if I ask my trans cooler question here.
I want to get a large trans cooler for my 3.8 Sable, I do a lot of driving on mountain roads, so I want something that can handle the load with ease. This car will also be driven in the winter, so I don't want to fluid to be too cold, if there is such a thing.
Where can I get one of the coolers with a thermostat, if i need one with a t-stat. Thanks
G
Discussion Starter #12
I woulda been pissed... but realized you're a Sable owner. So it's ok... lol jk, It's cool man. I dont mind
SableSal
I have the 679 Hayden which is the largest, most efficient that they make. If I remember right there is a bypass built inside the cooler so it doesn't over cool in the winter. You may want to check with hayden on that one though as I am not positive. It is rated for 30.000 lbs or a motor home, so I am sure that will be sufficient for a family sedan. :lol2:
As far as installation goes, there should be a write up in the modification section. The hardest part is the actual mounting of the cooler, since the hoses are easy to connect.
That looks like my 679 I just got. You will also notice that there is no way for it to bypass. Unless the temps are below 0F I would not worry about it. Even at -20F after about 20 minutes the tranny fluid will get warmed up.
Seems to work pretty well from just a touch to the factory tube cooler to that. The factory cooler is nice and toasty where as the new one isnt so toasty. :lol: B) It's a better peace of mind with it installed. I have another smaller one and I was contemplating putting that one in too.... but didn't. I like this style much better over the finned tube design. I was even going to install a fan and a temperature switch on it but the clearances were pretty tight so I didn't put the fan in. Should I? (My friend also gave that to me :D )
For all these secondary transmission coolers, did all of you guys disconnect the original coolers and completely bypass the factory unit? I was reading in the modifications page that it could be done either way, but that keeping them both hooked up together could be a problem if the fluids mixed or something.
If you only need the alternate cooler, couldn't you just remove the original cooler to get some more space?
Also, has anyone measured the difference in heat going past these things? I wonder how much the cooler air going into the engine compartment helps with the other parts under the hood.
What do you mean by "if the fluids mixed"? The trans fluid runs from the trans through a cooler, then through another cooler, and then back to the trans. There is no opportunity for the trans fluid to mix with anything other than more trans fluid.
JR
JR
Umm actually yeah there is. The stock cooler is part of the radiator. The transmission fluid runs through a cooler inside the right (passenger) side tank of the radiator, acting as a heat exchanger. Haven't you ever noticed the transmission lines going into your radiator?
If the cooler inside the radiator tank breaks, you have coolant and tranny fluid mixing; say goodbye to your transmission if this happens. I have seen this happen before on a friend's ZX2.
1 - 20 of 27 Posts
