Originally posted by sameboy@Jun 28 2004, 08:26 AM
will installing a tranny cooler void my warrenty extened care plan
2001 sel 24v
No it should not. However, if a problem is CREATED by the installation of the tranny cooler, the warranty will not cover that part. As long as the add on part does not directly cuase the failure of a covered component, your warranty will remain in effect.
Originally posted by spridget+Jun 28 2004, 03:49 PM--><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (spridget @ Jun 28 2004, 03:49 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-sameboy@Jun 28 2004, 08:26 AM
2001 sel 24v
No it should not. However, if a problem is CREATED by the installation of the tranny cooler, the warranty will not cover that part. As long as the add on part does not directly cuase the failure of a covered component, your warranty will remain in effect. [/b][/quote]
In other words... don't install the lines where they will be kinked and cause a drop in pressure and don't overtighten or undertighten the clamps on the hoses. Make sure there are no leaks and all the lines aren't kinked.... and you'll be just fine. If you plan on keeping the car for a while, this is definitely a good idea. :)
