I am looking into getting a tranny cooler (probably tube/fin) for my gen 4 and was wondering if anyone else has one on their gen 4.
If so, where do you have it mounted, and do you have the inlets/outlets on opposite sides or the same side?
Thanks
-Damon
Yep, mine is from the factory. I will check where it is and the routing later.
Mine is mounted vertically on the drivers side in front of the radiator with the inlet and outlets on the bottom.
Works great it added 87 HP
G
I think you've confused your 200mm MAF with your trans cooler.
Get the tub/fin style, inlet and outlet on the same side, and install it on the lower valance panel. SHOZ123 has his there, and I copied his install. Also, get the cooler in the 3/8" tube size.
