My Traction control actually dropps engine revs when it engages. If one tire has traction, it'll still run like normal, but only on the one wheel. If both loose traction, even if I mash the gas, the car will drop down the engine revs to bring down wheels speed till I get traction on at least one wheel again. If you're bouncing off some kind of governer, either your TCS works different then mine, or something is wrong.
As for the plugs, it depends how the governer is meant to operating. I believe some cut air to the engine, others cut fuel. If it is cutting fuel, you might be leaning out, which can cause problems. If it's cutting air flow, you might be running rich and not burning off everything, which could cause your plugs to develop carbon deposites.
Have you looked at your plugs yet? You might just wanna pull one to take a look at it. Maybe you wanna try running some fuel injection system cleaner through your gas tank too.
Another possibility is if you have some moisture in the tank. With the condensation and such, you may have developed some. You might wanna try tossing in some fuel stablizer you can get most anywhere you can buy auto fluids. Follow the direction on the bottle and see if that helps. Run the tank pretty much dry and put in a tank of fresh gas. If this is the problem, you may way to keep the tank no more then half empty durring the winter if you can help it. The less gas there is in the tank, the more air there is and the more chance for condensation to form. This is why when you store a boat for the winter, you're supposed to put a full tank of gas with fuel stablizer in the tank.
-Dan
PS: I've moved this thread to Maintenance and Repair, as this isn't really performance related.
