first, let me apologize if this is somewhat long-winded. i am not much of a 'car guy', my knowledge is limited to whatever i can dig up on the internet. i don't have a shop and am not much of a mechanic. i will do my best to give the best description of my problem so as not to be a burden for anyone who wants to reply to my post here. thanks for understanding.
i will give a summary of what i've gone through before getting to the problem i am having currently. if you aren't interested in hearing this horror story, scroll down to #2.
#1 - history
i bought this car in november of 08 for 700$ from someone on craigslist in mesa, az. the alignment was off, pulls to the left, otherwise the only problem the car had was the battery needed replacing, and the power steering pump was going out.
when i bought the car it had 84,000 original miles on it, and i have documentation of every oil change the car ever had. was owned by 1 person until i bought it, and it was fairly well taken care of.
without so much as taking it in for an inspection or an oil change, i got the car registered, insured, and checked for emissions - 2 days later i drove it 1300 miles to billings montana.
when i got into town, i took it to a mechanic for an oil change, a new battery, and a new power steering pump. about 300$ later, i'm on my way.
3 weeks later the car started knocking. a few more miles down the road, it threw a rod. took it back to the mechanic who did the initial work, and he found a 3.8 from a 1990 with 89,000 miles on it. i had him install it and paid him 1700$ to get it fixed. got the car back a week later.
within about 10 days, it blew a head gasket.
come to find out later, the guy who did the oil change spun the plug too tight and the oil slowly leaked out over several weeks which caused it to throw a rod.
mechanic wouldn't honor any of his posted warranties so i had it taken to another shop. new head gasket installed among other things, 1200$.
no major problems for a year and a half, however the car was driven very little during that time.
#2
in november of '10, one evening i went to take the car to the grocery store - it is getting cold in montana at this point. i turn on the defroster, car dies. turn key off, try to restart and notice a clicking sound coming from the engine compartment. open hood and find it coming from a black box next to the battery box/radiator. research tells me this is a pcm/ecm/eec-iv radiator mounted unit. i pull one from a junkyard and swap it out. after fiddling with the rotary knob which controls the vents/ac for a while, it stops clicking and i have the vents set to off. if i turned the knob at all, clicking would resume.
manage to drive the car to the shop. at first it appears about 600-700$ to service, had some vacuum locks and needed some other services - rebuilt starter, etc. after working on the starter, it is discovered that the flywheel has broken teeth and will need to be replaced. bill goes up to 1600$.
a week later, get the car back. drive it home - maybe 8 miles from the shop - park the car and go to bed. wake up next morning and go to a doctors appointment. car doesn't display any problems other than it still is out of alignment. running great at this point - it should i've sunk almost 6000$ into it by now.
after leaving my appointment, i get out of the parking lot and onto the road, and the gas pedal is kind of "sticky". it will move maybe a half inch before more force needs to be applied. note that the weather at this time is approximately 20 degrees and snowy. also, it is shifting kind of funny - tach shows at times 2500+ rpm before it shifts up, and on deceleration (coming to a stop light or stop sign, preparing to make a turn) when the car downshifts it almost feels as if i'm being rear-ended. downshifting very hard.
shop is on my way home so i stop in and have them look at it, since i just paid a lot of money to have it repaired. an hour and a half later, mechanic comes in and says 'seems like there was a sticky valve in the transmission, i put in an additive and took it for a drive around the block - seems to be running fine now'.
i drive the 8 miles or so home and agree it is running fine.
this morning i get up to do some xmas shopping, exact same thing as before. gas pedal seems "sticky". downshifting hard again, not shifting up at the right rpm.
i called a transmission shop after speaking with my mechanic, he mentioned perhaps a servo issue, or something with a pin sticking. i read online perhaps throttle position sensor, or using carb cleaner on the butterfly valve (after so much work has been done on my engine and the little it's been driven it seems unlikely to me there is any buildup in the throttle body, but i have yet to check)
it isn't a throttle cable sticking, as even after the car has been warmed up for over a half an hour it still does the same thing. i'm scared to drive it to the shop as i don't want to cause an accident - the roads here aren't forgiving at the moment due to snow/ice.
before i throw another 1000+$ down the toilet, i came here to you. this is my first post here. any information anyone can provide would be greatly appreciated.
at this point i've got so much $ invested in this car there is no way i'm gonna give up on it. but i am kicking myself in the ass for not buying something else right now. family is considering lawsuit against mechanic who did initial work on the car, but the cost there might outweigh any benefit.
thank you, in advance, for any help you can provide me.
happy holidays.
-e
#1 - history
#2
happy holidays.
-e
