Trying to find the right tools to install the clutch coil and the clutch is virtually impossible. Wondering if anybody knows where to buy these tools. The only place I could find them was "handsontools" and they were rather expensive. Nothing even on e-bay. Do people just not use the special tools to put an AC clutch on the FS-10 compressor? If so, how do you get the coil and clutch on?
You do not need the special tools. Use a screw driver to wedge the clutch take out the socket head capscrew. There is a larger hole for a bigger screw to pull the outside of the clutch off. Remove the snap ring. and it is off. Be careful not to loose the shims. If you whant to buy the tools a store like tool topia or one of the online ac stores have a tool for holding the clutch from turning.
