Would my low profile winter tires from my 1997 Pontiac grand am GT with the number 205/55R16 / 90S M+S fit onto my 2000 ford Taurus LX with the numbers P 215/60 R 16 94T ??....i would obviously have to put them on different rims to match the bolt patterns but i just wanted to make sure they wouldn't be to thick or wide for the body of the ford.....
They're narrower and shorter than the stock size. With those on the front, the speedometer will be 4.9% fast - when the speedometer says you're going 60mph, you'll actually be going 57.
Tire size calculator
That's a yes, assuming all 4 tires will be the same size. As noted above your speedo will be off by ~5%, but the tires will fit ans work fine. They'll just look a little small in the wheel wells.
