1 - 9 of 9 Posts
· Premium Member
How do I do it?
I went to the junkyard to pic up the SHO slicers, but I don't want the tire, and of course they'll charge me for them. 2 of them are shot and the other 2 are OK, but someone cut the valve stems, so they'll have to come off anyways. Plus I don't think they'll fit in the car with the tires, not to mention making a mess. So how do I get the tires off the rims by hand? I've got a prybar, hammer, mallet, and a tire iron as mechanical implements at hand, and can probably get others. Obviously I don't want to chew up the rims either. Plus I'd have to pay the disposal fee for the tires if I took them. That's another
for me. Thanks guys.
-mobiuslogic
· Premium Member
AWW!!! Of course, and my dad has an 18V Ryobi system I can hijack. HeHe
-mobiuslogic
· Premium Member
Get them removed at the junkyard. Most "U-Pull-it" yards have a station near the big pile of alloy wheels where you can demount the tires. If they don't, there are a variety of ways to remove the tires. First choice would be to use a bead breaker, which you obviously don't have. One way that worked for me was to use a 6' long 4x4 post, a small hydraulic jack, and one of the beams that supports the second floor of the garage. I put the 4x4 on the tire, next to the edge of the rim, and then put the jack on top, and against the ceiling beam. Then I used the jack to basically drive the weight of the entire second floor onto the tire. Worked every time.
· Registered
good luck getting them off by hand. It's hard sometimes even w/ the right machines. But you do need to break the bead first (the part that touches the rim) then with 2 ppl you can pry the wheel off using 2 crowbars the longer the better. and just do one side of the tire at a time, you'll never get both.
· Premium Member
Discussion Starter · #9 ·
I'll check to see about them taking the tires off. Didn't think about that. Hopefully there isn't a fee.
-mobiuslogic
1 - 9 of 9 Posts
