Originally posted by Markus+Jan 19 2004, 05:59 PM-->QUOTE (Markus @ Jan 19 2004, 05:59 PM)
@Jan 19 2004, 05:55 PM
The colder it is, the higher you want the air pressure. The hotter, the less since air expands in heat.
You want the same pressure regardless of ambient temp.
If you correctly set the pressure in the summer, you will need to add air to the tire in the winter. Note that you are not adding pressure, you are adding air. The act of adding the air increases pressure.
I keep the tires of my SHO at 35PSI year round. I remove air in the summer and add air in the winter to accomplish this.
Mark
95 SHO [/b]
