I thought my small coolant leak was from the water pump but after some disassembly (gotta love the cramped 3.8 workspace) it appears that it is not the pump but leaking from the timing chain cover gasket.
Yay. Looking at the Chilton's this looks like a major PITA. You have to remove the power steering pump, a bracket on the a/c, the oil pan, the distributor, water pump pulley and the crankshaft damper/pulley. Does AutoZone have a tool for yanking the damper?
I'd love to take this to a mechanic but after just spending $400 for a new radiator & upper/lower hose install I can't afford $500-$600 to have them do this.
It's not a large leak (that was the radiator
), only about a quarter size drop on the ground in the morning but I don't want to let it go too long and cause bigger problems down the road.
Isn't there an oil seal under the timing cover as well? Should I go ahead and replace that at the same time?
