Ok I went out to check my timing chain and i figured a good way to test it is to take the distributor cap off and turn the engine clockwise till the rotor moves then turn it back the other way. It should start moving right as i turn the engine back the other way right? Well when i did it it did not it took about a whole half turn of the crank before it starting moving the other way is this normal i don't think so
It is a 87 Vulcan with 117k on it. It is running rich and i get a popping upon deaccel and had a hard starting when cold but these problems don't happen all the time intermmidate as hell
