Two years ago, both of the front outside tie rods were replaced. This month the same mechanic told me the passenger-side front tie rod needs to be replaced again. I paid him to get it replaced anyway. My question is: Doesn't tie rod last two years?
Most aftermarket tie rod ends come with grease fittings, and are not greased at all from the factory. I am wondering if the mechanic forgot to grease it after the install No grease = real short life.
My 04 Duratec has had small oil leaks on and off for the last few years. Oil hitting the ground has typically stopped or slowed when I've used thicker oil and sometimes it's stopped after an oil change.
Ideally I would have switched to high mileage oil but I have a small stock of 5w20 that I...
Anybody feedback for me what that could be???
2013 Taurus. 119K on it...
Last week I got twice within 20miles the error message “engine coolant overheated” RED error message left display section!
Immediately turned the car off and pulled over. That happened like 5mins after leaving the house...
2002 Taurus SEL 177K miles.
Trying to decide whether to repair or put repair money towards used car. I am not skilled in the mechanical arts, and will rely on a mechanic to do everything.
The car is in overall good shape. It has a slight oil leak. I add a quart between changes usually. Never...
I get toasty air from my heater long before the temperature gauge starts to move. Does this car with the DOHC V6 use the same temperature sensor for the computer and the gauge, or are they separate sensors?
Possibility that a faulty temperature sensor is making the computer open the IAC to...
Hello, my normal idle RPM was about 700-750. It started to bounce down about 50 RPM and then back up when stopped at a light. It was recommended that I clean the IAC. Used throttle/carb cleaner on the IAC until clean and also sprayed in the two holes on the throttle body. Very simple to...
