Originally posted by SableOHC+Feb 26 2004, 01:18 PM-->QUOTE (SableOHC @ Feb 26 2004, 01:18 PM)
<!--QuoteBegin-Bob Gervais
@Feb 26 2004, 10:38 AM
Proper throttle plates should have a slight elliptical shape to them, and also be angled on the edges. If that's what you're seeing it's not wear.
Hmmm.....Are the plates longer parallel to the shaft or perpendicular to the shaft? [/b]
Perpendicular usually, on a round TB.
Before we jump on the guy, i suppose it could happen. When the throttle closes, the plate rests against the inside of the TB bore. If you look inside one, and open the throttle, you will be able to see the shiny spot where the throttle plate contacts.
I agree with Paul, I've never seen one wear out, and AFAIK it's not a standard replacement item, nor would I know where to get one. My guess is that if it is worn, the only way to repair it is to either fabricate one, or swap the TB for another that's not worn.
I trust Paul when he says "in all his years". Gotta have respect for a guy that was there to witness the invention of dirt.
