1 - 11 of 11 Posts
would the tec cams fit in the V6 SHO and vive cersa?
i'm asking because of the new cams avalable for the SHO
I'm doubting it..... but hey you never know.... anyone?
Was waiting for you to chime in :D
mmm...chains..chains are good. jello is good too, and there's always room for jello.
is the sproket bolted on the same way on both vehicles. I believe the SHO has 3 bolts on the end of the camshaft.
i'm only asking because it would open up a bit of a aftermarket for the tec since mikey introduced his new cams. btw he has dyno results on the +20 (mild) and the +40 (more agressive) is to come.
like you said, it was a long shot. No there not attached the same. You have a better chance of making a new camshaft from and old vcr using a dremel and hammer.
Brad
G
Brad
Remind me to hide the Dremel there, McGuyver. :p
Also, Duratec guys should be able to use cams that fit an SVT, right? Dont they make adjustable sprockets for the SVT, to adjust cam timing?
1 - 11 of 11 Posts
