1 - 20 of 31 Posts
Overheating Duratec V6 3.0L
First of all, hello to everybody!
I got here looking for a solution to my problem. My 1996 V6 Sable overheated tonight and leaked lots of coolant... I was with my child in the car, so I drove it home with the heat gauge to the max. I did add some water on the way from a gast station. Expansion tank was spewing coolant. No strage noises from the engine thou...
Looks like is coming from the bottom, passanger side engine bay. Reading on the net I found out that that where T-Stat is located? And is an expensive hose that breaks off there?
Is night now, cannot work, does anybody have some pictures of that area? Is that for real, the Ford engineers put the T-Stat on the bottom of the engine block???
Yes, you have to remove the black plastic splash guard and access the stat from down below pass. front area. If its the $160 rubber/metal by-pass hose from the bottom of the water pump to t-stat thats leaking, you can hacksaw old pipe in half to remove and replace with a 1.5in. diameter 22in. long flex hose and zip tie away from the belt.
How long did you drive it with the heat gauge pegged? I know on my Vulcan all it took was about ten minutes to crack a head.
Like 10-15 minutes. I had the child with me in the car, I thought the the T-stat was closed and the coolant is boiling over (that I thought explain the pool of coolant under the car when I stopped). The gauge was at the maximum limit of the "normal" zone, not on red, so I thought that is OK.
Now, after reading the thread about corroding metal pipe that connects the T-Stat to radiator, I think that the gauge was measuring just steam.
So yes, I might have also some blown gaskets now. At the best :(
Cake monster
I got here looking for a sollution to my problem. My 1996 V6 Sable overheated tonight and leaked lots of coolant... I was with my child in the car, so I drove it home with the heat gauge to the max. I did add some water on the way from a gast station. Expansion tank was spewing coolant. No strage noises from the engine thou...
It would have been wiser to pull over, I would highly recommend it next time, it could mean the difference between a working engine and a ruined one. If you rely on this car as your main transportation, it might have cost you the ability to drive your child to school, etc... Not a good idea. You'll be lucky if it didn't ruin your car. Sometimes people need to ask themselves "Is it worth the few hundred for a tow or $1000 to replace the engine, or even more to replace the entire car", the sane choice is obvious. Everyone thinks they can get home, why do people think they can gamble with a cooling gauge? Your engine cannot function without cooling, if there is no cooling then you need to stop driving it.
Yep, I know. I didn't think that the gauge will not be indicating right (wasn't on red yet), but now I know more.
Luckly I have another mean of transportation so... it is what it is. I will get under it this weekend if nothing else comes by.
I had that hose that is supposedly 160 bucks on my 99 sable duratec rub a hole in itself, it is not 160... i got it for 50 bucks at advance auto. its not a Motorcraft part, but it got the job done, and yes the thermostat is on the bottom of the motor.
Cake monster
Hopefully she'll work just fine afterwards. I don't know much about what happens when a Duratec overheats, but if you had a Vulcan you would need a new set of heads. Was there any signs of a blown head gasket? Missing? Sweet Exhaust? Watery oil/oily water? Combustion gases entering the cooling system? I haven't heard anything in the thread that would make me worry about the heads yet.
Discussion Starter · #10 ·
I got a hose from AAP to replace the pipe - it is the 1.5"x22" radiator hose used in some Jeeps/Dodges. Has a sping inside so it won't collapse when I route it.
I hope that when I start her, won't see white smoke... on exhaust :(
Pearl drummer, good to know said lower by-pass hose assy. is available aftermarket now. Originally, it was dealer-only at $160-180 a pop. Thanks. A couple years ago i bought an upper radiator hose assy. for the drivers side which had a plastic tee and 2-3 hoses attached for $25-30 at adv. auto. Its been fine. I believe the brand name was Drive-Rite.
If the weather was REALLY cold when this happened, you may be OK. One of the nice things about a Tec is its all aluminum engine block, it can be like a giant heat sink in really cold weather. Good luck, hope everything turns out good for you!
Discussion Starter · #13 · (Edited)
OK, updates.
Good news (for me). The pipe that is usually rusting looks all right. I didn't loose the coolant after all thru there. I have lost lots of coolant thou - the expansion bottle is dry, upper hoses have air in them... Don't know if overheating from a stuck T-stat can do that?
Bad news... I still cannot see the location of the T-stat. I took a pic of the place where it was supposed to be and it doesn't look right to me (I see just a water pump outlet). Is the T-Stat in that water pump outlet???
I am attachimg pictures maybe someone smarter than me can point to right direction.
Follow the rubber/metal hose (the one you bought the replacement for) from the bottom of the water pump to its other end (thermostat).
Discussion Starter · #15 · (Edited)
That is right above the metal crossmember!
Thank you, I think I saw it now! Is that thing at 10 o'clock from the oil filter...
Discussion Starter · #16 · (Edited)
Thank everybody that cip in. I did replace the monster. Pic is below - looks like some of the wax came out. Lasted 17 years... I guess is not bad.
I will take a test drive now - for now I don't see/hear nothing worrysome at the engine/exhaust.
LE: I did test it. At the beginning it seemed that is acting right - temperature slowly rised, then the termostat opened and temperature gauge dropped a little bit (the original one didn't do that drop, this is a Stanton).
But then, after 5 minutes, it started to rise again towards the maximum. The radiator fans are working full blast. If I turn the heating in the cabin, I don't get nothing but cold air, even if the temperature is almost on red line.
Could it be the water pump? It sounds a little funny but I had coolant overflowing on the belt and water pump so I don't know if it is from that...
No heat would be a blocked heater core (rare issue on Tecs) or a dysfunctional heater blend door actuator motor (more likely).
Possibly a water pump issue also, but Tecs don't dissolve their pumps like Vulcans do.
Discussion Starter · #18 · (Edited)
It would be a huge coincidence - heat was working just a couple days before.
I got a water pump from AAP tonight... I will remove the one from the engine maybe tommorow. Hope that I find the impeller trashed, because I am running out of ideas.
Tec impellers usually dont corrode away like vulcans, but they went through a stretch in the gen.3s where they would break off. Possibly a bad batch? Iirc, there was a tsb concerning the issue. Ive had it happen on 2. If the pump doesnt resolve your problem, next check would be for a clogged or partially clogged heater core. Ive also had a couple of those cause overheating probs. over the years. Remember, coolant is always flowing through them no matter what ac/heat setting is being used. There is no core by-pass hose on the tec.
Discussion Starter · #20 ·
Good to know. I was looking for that bypass valve and didn't see it.
Anyway, the heating issue I think is secondary if I cannot fix the overheating of the engine. I don't think a clogged heater would do that - the radiator should be able to work alone, no?
1 - 20 of 31 Posts
