Just an FYI for those who may need to do this is the future. The thermostat on our car was located by the battery. THere are two hoses there that run one over the other. The top hose needs to be taken loose and moved up and out of the way so you can access the hose underneath it. Then take the three bolts out of the thermostat housing and move the lower hose off to the right, it's a tight fit but I was able to do it without taking the hose clamp off, though that might have been a little easier...not sure.
Hope this helps,
Shawn
Thank you... I am doing this right now, and can't find it. I will try to get some pictures. Some other site had me pulling the air dam off the bottom of the car, looking at the radiator... that is wrong for the 04. Thanks for this tip.
