1 - 20 of 113 Posts
Meet the vehicle I refer to as "Bull 2.0," the AWD successor to my first G6 bull that was FWD only. Much like Bull 1.0, it's Tuxedo Black with black cloth interior and 3.5L N/A engine:
Getting interior cleaned at Delta Sonic:
Ford Factory Options:
-201A (MyFord Touch w/backup camera, center speaker, reverse sensing, non-memory adj. pedals)
-Rear Spoiler, non-SHO style
-Non-Flex Fuel (California Emissions)
Mods at this point in time:
-Separate snow tires and rims (General AltiMax Artics)
-Police Interceptor grille
-New Kenwood speakers (4)
-Lukas LK7900 dash cam, hardwired
-Ford Remote Access (smartphone based cellular remote start, impact alarm, and SMS alerts)
-AWD Torque Gauge (As Built Data change)
-Amber Daytime Running Lamps (IDS option)
-Mounted ScanGauge 2.0
-Factory Navigation courtesy of Ford PI Mods
Troy McClure says: "You May Remember My Car From Such Meets As:"
-Ford Nationals @ Carlisle, 2014
-TCCA Albany @ Crossgates/Thatcher, 2014
-TCCA Toronto/Oakville, 2014
Discussion Starter #2
Repair post:
-Body shop is going to repair the car wash's damage, at the car wash's expense. A terrible scratch was put in, ugh.
-Also going to see FMC body shop for warranty work. The trunk mounted light on right side was not aligning with it's tailight counterpart. Upon closer inspection, Chicago did a poor job installing the lamp, and did so in such a poor fashion that it wore down/scraped/damaged some paint on the trunk above the lamp with some wear on the part itself. Bummer, but hopefully will be easy to get covered.
Dashcam is running well on the vehicle and hasn't killed the battery. Woo!
Discussion Starter #4 (Edited)
Bought it new, but those are winter-designed wheels from Momo.
win-pro-black
Threw some General AltiMax Artics on there and it's a force in the winter. Both wheels and tires came from Tire Rack.
Maintenance update:
Body shop work kept the bull down for 3.5 days last week. Two working days were needed to repair the damage Delta Sonic inflicted, and another 1.5 days were needed to correct some paint damage on the trunk from a misassembled light module on the right side. Paint had chipped and was severely uneven with the corresponding right tail lamp on the body.
The lights are more even now, though not perfect. The paint damage on the trunk was also corrected.
Also threw some cash out of my own pocket to PDR a weird dent that didn't appear up close, but distorted the continuity of the door on the rear pass/driver side. Cost way more than I expected (almost double my last PDR, and above the price I was originally quoted by nearly a third), but it was worth it just to get it all done during one of the body shop visits. Good to have a slush fund.
Picture update and repair (sort of) update.
Went back to the selling dealer to get a TSB done that re-enabled the Compass menu in the right hand side of the cluster. Except we couldn't do the TSB as written.
A while ago, a source figured out how to enable the AWD gauge in the LH side of the cluster. Applying the TSB as written would pull OASIS as-build data to blank this change out. So the dealer went ahead and made manual programming changes to the cluster to retain the AWD and enable the Compass selection.
It worked.
And for posterity, have a money shot.
Put a monster battery in tonight as the stock battery was questionable for supporting the parasitic loads on it now -- Ford Remote Access and the dash cam.
Went from 540/675 (0F and 32F) CCA BXT-59 to the 850/1090 CCA BXT-65-850.
Huge boost in reserve capacity, too. 100 -> 165 minutes!
Can you post a little more on the whole dash cam setup you have? I have wanted one of those for a long time, and I am curious about your setup.
Discussion Starter #11
Sure, Paul.
It's a Lukas LK-7900 unit. Bought it with an included 16 GB Class 10 SXHC card.
It's running 24/7. My unit is configured to run in 1080P HD when driving, and saves footage selectively in "parking mode," so if it detects an impact, it'll write to the card. Motion sensor settings are also available.
I'm fairly happy with it. It's pricey, but I think it works well and should last (knock on wood). You can get cheaper units, though, this one goes for over $200. Night quality is acceptable, day quality is reasonably good.
Discussion Starter #12 (Edited)
Might or might not have a new project here.
Unbeknownst to me and only discovered while parsing through the Workshop Manual, the 2014 Taurus could come equipped with a heated, power, AUTO DIMMING, driver's side external mirror. I would LOVE the dimmer mirror. Never understood why our Fusion had it, but never the Taurus.
In any event, the WSM states that the LH external mirror derives dimming information from the interior rear view auto-dim mirror. However, I can't seem to figure out how that passes from one mirror to the other to see if this project will work, and if it can be a drop-in situation. I have a feeling it might be. The harness seems to already be wired with the 2 pins that are required to make the feature work. So the glass and motor(?) would need to be replaced, but otherwise it should be PnP from my estimation.
If I get a better idea of how the mirrors share that information, I might just plod ahead and try this mod if I can get the parts reasonably.
Owner of #RaceSable
You need to update this, I saw this car at the Albany meet...
Discussion Starter #14
Nothing to really update.
Snows went on today. Project in post ##12 is axed because Ford never made a dimming blind spot mirror, only BLIS.
Wax job going on tomorrow. If the weather is good in the next few days I'll get some pictures with the snows back on. But they'll look just like page #1.
Discussion Starter #15
Detailing came out absolutely great. Shared these with Paul the day after, but this is where it is now.
The bad news is that one of the post-recall plate lamps has already failed. Dealer trip on Friday, unfortunately.
I approve.
Discussion Starter #17
Thanks, Paul.
And I gotta say, the tire shine on this--can't see on the pictures--looks nice. Looks like I'll be getting some use out of my Carlisle
winnings after all.
Discussion Starter #19
Brief update, everything is going quite well.
A week or so ago I almost killed the monster battery by leaving the dashcam on in single digit cold. So for now, the camera remains off (sadly).
On the upside, I did get some winter pics. A sample.
Nice! Even though I hate the cold, love the winter scenery.
1 - 20 of 113 Posts
