anybody have any insight as to what I'm looking at here? (specifically the hard aluminum looking bend)
thought I had a vacuum leak.. turns out I was correct. Forgot to plug a hose back in.. BUT the car still doesn't sound quite right.
Tire Automotive tire Helmet Automotive lighting Tints and shades
It would help if we saw a full photo of engine and then a zoom in with correct front/back orientation. And if we knew what engine this is (vulcan vs. duratec)
That elbow is actually plastic and is at the leading end of one of the heater hoses. On the end is a quick connect fitting for the metal tube that it connects to that leads to a rubber hose that in turn leads to the water pump housing. That elbow & fitting can be brittle after this many years, so be cautious when handling it.
Are we talking about the same part?
Hood Automotive lighting Automotive tire Car Vehicle
Now that you've circled the part, no. Thought you were referring to the elbow above it. I have a '04 Sable with the same engine and just took a look. Nothing like that on mine. Only thing remotely close to that is a wire harness that has a flexible aluminum heat shield wrap around it that passes further down next to the tranny dipstick tube and disappears between the engine and tranny. Not sure what that harness feeds.
Discussion Starter · #8 ·
Now that you've circled the part, no. Thought you were referring to the elbow above it. I have a '04 Sable with the same engine and just took a look. Nothing like that on mine. I've pulled engine parts from both years (Taurus & Sable) and they always looked the same. Only thing in that general area that has a metal-like appearance is an aluminum heat shielding wrap around a wiring harness that leads to a connector clipped to the top of the tranny...but, on mine there is no bend in it. The connector may lead to a rear O2 sensor...but, not sure.
Thanks for clarifying!
