Discussion Starter #2
I have a 2015 SHO that I’m having a couple issues with. The first is when driving and slightly turning the wheel to the left there is a slight hum or grind noise. You can almost feel it in the pedal and that’s the only time it happens. The second is the dome lights and steering wheel lights don’t work. I’ve tried the toggle. Have had the battery replaced so I would assume that would reset it. I have checked fuses or pulled any codes. All other lights seem to work fine. I figured someone could point me in the direction of existing post as I could find anything that seemed to match initially.
Thanks guys!
Welcome Eric! If you haven't already, may want to check out the Ecoboost Owner Forums and the Ecoboost Performance Forum. Also, check out member bpd1151's (Mike) garage and posts on here. Hum/grind may be a faulty rf wheel bearing/hub assy., abs sensor or harness, or even a bent brake dust shield.
