I want to say THANKS to the forum. Not sure this is thread worthy, but wanted to share my experience. I have a 2002 OHV Vulcan Taurus wagon. I had what I thought was bad fuel for the 3rd time in 4 months. First would be the odd miss in overdrive going up a slight grade. Next it had a random miss. Lastly I had a horrible misfire when starting after a short hot soak. The MIL was on and I had both a random misfire and a P0301 for Cyl 1 Misfire. The plugs and wires were only 3 months old, so they weren't suspect. Scrounging the forum I found that the either the coil or the Camshaft Synchronizer were the suspects misfire or for the miss in Overdrive. I changed the coil first, misfire seemed almost fixed, however still didn't seem perfect. Additionally, THROUGH THE FORUM, I realized that annoying chirp I was hearing was NOT the belt but the Camshaft Synchronizer. OK, That was next. Using the info from the forum (which made it very straight forward) I changed it and just got back from the test drive. WOW, what a difference. Runs like new now. What's odd is I have been having issues for a while and until it really went BAD, no codes were thrown. I was previously oblivious to the Cam Synchronizer failure, so this helped me big time! Digging through the forum has been the best diagnostic tool available! Thanks again.
very good, i too was having the same problems with my 01 ohv. i googled my problem and it took me here. i been here ever since. stick around and you'll be able to fix anything on these cars. these guys and gals know everything about the Bulls!!
Spend my 02¢ wisely...
As good as on-board diagnostic systems have gotten, they are not perfect and often are only as reliable as the data they're receiving. Sometimes you've still got to do a little research/testing to get to the bottom of a problem. I'm glad the site was able to help you figure it out and get your car running well again.
Sent from AutoGuide.com Free App
Just learned why I heard a belt chirping sound coming from the wrong side of the engine for it to be the belts last night, oh dear..
After starting the car in the freezing cold last night I am 100% sure I also have a failing camshaft synchronizer. So thanks to everyone in this thread! Very convenient timing because I had absolutely no idea what it was.
About this Discussion
6 Participants
Redcoat17
Full Forum Listing
