I'm wondering if any of you guys have had this happen to you or know of anyone that had it happen. I have lost overdrive. Car will not shift into 4th, otherwise the transmission is smooth and normal. My SES light came on and at first just disconnected the battery and took off and put back on the gas cap. This reset the computer. The next day which was the 4th drive cycle the light came back on. Went to Auto Zone and got it scanned, these codes came up PO761- Shift solenoid C and PO734 Gear 4 incorrect. After talking to my mechanic I took it into the shop thinking it was probably a corroded connector or something and it turned out to be an internal problem. This Tech Service Bulletin seems to cover my issue, but after taking the car to a couple places it doesn't seem to be real common. This bulletin says that a broken retaining clip in the valve body that secures the forward clutch control valve and spring in place may be the cause.
The estimate I have gotten is $900 plus tax in addition to the $95 I spent on the diagnostic.
