Hi there.
I have a problem of overheating with my 92 sho MTX in Brazil. Normally the temperature on the gauge was in letter A with the car running, but now, is o the letter N, after this point start the fun.
I changed the sensors and control relay, I made a flushing but the water was clear. Today a changed the gauge, but the problem continue. There are two sensors, one of the gauge and ohter of the PCM. I changed both
The radiator and water pump were changed one year ago, are new. I changed the cap of the radiator too.
I don´t know more where I find a solution. Tomorrow I will try to find a restricion on some rose.
I´m not sure if is possible some problem on the water pump without leak.
If someboy have a suggestion, I will appreciate.
Thank you.
Thank you.
