PREMIUM SOUND - GEN 2 - GL
Hi, does any one know if the gen 2 GL base model sound system
came withe the Premium Sound option? I do not see a plug any where
under in my trunk under my rear dash for my silver amp to plug in to.
Thanks in advance.
under my rear dash for my silver amp to plug in to. Thanks in advance.
May check the trunk?
Pull back the trunk carpet on the left side, the rcu is behind wheel well. If it is a plain aluminum box = standard. If there are cast aluminum fins = mach.
Discussion Starter #5 (Edited)
I have a 95' GL model with the base model stereo and wish to upgrade to the Premium sound.
The amp shown and bracket goes behind the back passenger seat in the trunk area under the seat shelf of an LX but I do not see any where there is a plug in for the amp in my GL. Did the GL have an option for the Premium sound. Thanks in advance..
Even the cheapest POS aftermarket head unit will completely outperform the OEM premium sound system, plus will likely give you a USB input and and a 3.5 mm pin plug aux input. Go up in price a bit, and you will also get bluetooth, a graphic equalizer, etc.
