Shipping is NOT included with these prices...will try to use USPS Priority Mail flat rate for sake of simplicity and price & speed of shipping, but can work out alternative arrangements.
OK time to clean out some stuff I've grabbed at yards in the past few years. If you would like pictures of something I don't have pictured, I'll be happy to take some. Click here for pictures of the items for sale:
Feb2011Sale pictures by beachbum86 - Photobucket
Email is a better way to reach me: nick(9)(8)(6)(AT)gmail-dot-com, but you can PM me (can't check TCCA as much when at work...)
Interior Stuff
00-03 Medium Parchment (beige) style, dual visor, with adjustable lighted mirror...has secondary visor. Both driver & passenger. Comes with entire harness past connector in passenger a-pillar. All cleaned up and ready to go. Color matches any Gen 4 Beige interior. Dump those unlighted, single visors for these. They are from a 2001, so the screw holes are exposed (2000s and 96-7s have a plastic cover). $30
--HAS BEEN CLEANED SINCE PICTURES--
00-03 Medium Graphite (gray) style dual visor, with adjustable lighted mirror, has secondary visor. PASSENGER SIDE ONLY. Add back the missing visor on your later built 01/03+ 2003 Taurus, or replace the ripped one. No harness, just the connector is there. Is from a 2002, so screw holes are exposed (2000s and 96-7s have a plastic cover). Works in gray and dark gray/black interiors, same headliner $10
00-03 Medium Parchment(beige) style dual visor, with adjustable lighted mirror, has secondary visor. DRIVER SIDE ONLY. Replace the ripped visor . No harness, just the connector is there. Is from a 2000, so screw holes are covered (2000s and 96-7s have a plastic cover). $10
(SOLD) Cargo net for a Gen 2. Has a couple of tears, but still in great shape. $5
Center rear seat belt for a Gen 3 that goes across chest. Gray in color, from a 96/7. $5
(PENDING SALE) Auto dimming/compass mirror Gentex 177 (GNTX177). Base unit plastic tabs are busted, but still holds around base OK. Wiring included, will need to extend and tap as needed. $5
1996-7 Willow Green interior moonroof motor access panel. 1 clip busted, otherwise there. $5
1998-9 Gray interior moonroof access panel. Great shape, $5
Gen 4 Sable LS Prem AutoLamp/Fog light switch. comes with snipped wiring harnesses. Still in decent shape. Does light up. $15
Wheel center caps:
(PENDING SALE) 96-97 Ford Taurus SHO painted wheel center cap (not chrome). B- grade. Definite wear on it. $5
(1 of 2 left) 2003+ Mercury Sable alloy wheel center cap (like this one: http://www.wheelcollision.com/wccpix/3360silver.JPG ) Has small tear from bozos tearing plastic a tiny bit but good replacement. Have 2 available, $5 a piece.
Exterior/Engine bay:
Toreador Red driver door handle w/keypad cut out. From a 98. Matches 96-12/02 built style door handle. $5
Gen 4 SEL/LS Prem hood alarm switch with good condition rubber topper. connector with donor leads included screws included. $10
96-99 V8 SHO Motorcraft IAC (as indicated by the blue dot on top and yellow dot on the underside. F6LZ-9F715.... or F6LE-9F715... removed from JY car, but like new shape, minus minor surface corrosion: $30
Gen 3 SHO front bumper license plate "bracket" (it's plastic...does that make it a bracket). Silver Frost (TS paint code). Comes with proper screws to mount bracket to car and mount plate to bracket. Came from car w/156K...it has wear $20
Audio:
(1 available) Gen 3 MACH Audio Package (removed from a 98): 98 part number RCU & MACH branded tweeters. Everything has been either run through the dishwasher and/or wiped down, tested, and reassembled. $75
(2 available) Gen 4 MACH Audio Packages (removed from 2000 & 2001): XF1F/Y2K part number RCU. MACH branded tweeters. Everything has been either run through the dishwasher and/or wiped down, tested and reassembled. $75 each
I have sedan and wagon brackets available...check with me to see availability on wagon brackets, currently 1 on below RCU and 1 spare left. No additional charge.
Gen 3 MACH RCU, F7....-NA Blt 49th week 96. Wagon bracket, ready to rock for any 96-05 wagon. $40
(3 available) Normal length trunk mounted CD changer harnesses $10 each
1 longer than normal CD changer harness for trunk mount, $10
1 super long CD changer harness with aftermarket audio connections, etc. $15
Interior Stuff
Wheel center caps:
Audio:
