1 - 2 of 2 Posts
Hi. Have a 96 Taurus 3.0 OHV Vulcan. Just replaced some coolant sensors and housing. Now car wont start. No engine codes. Fuel pump is heard priming. Replaced fuel filter. Battery strong. Was starting fine before I replaced the pressed-on sensor housing. Am getting wires out of the way to check camshaft position sensor but also came across this unattached electrical? ribbon found on driver's side. There is a similar ribbon on passesnger side which seems to be a ground wire perhaps. Anyone know where this ribbon is suppose to attach? (see pic that shows ribbon under hood drivers side close to cowl) and if it could have anything to do with car not starting now. Thanks a bunch.
almoat looks as if if it got pinched off one time in the hood latch. i would say inspect the general area for apiece of ribbon, bolted to something... not sure what else
$hade
1 - 2 of 2 Posts
