Well I got the heads and valve covers painted, with the heads torqued down. Now I need to reinstall the pushrods/rockers. Is this still the correct procedure:
Dip each pushrod end in oil conditioner or heavy engine oil. Install the pushrods in their original position.
Before installation, coat the valve tips, rocker arm and fulcrum contact areas with Lubriplate® or equivalent.
Rotate the crankshaft one full turn (360 degrees) until the lifter is on the base circle of the cam as shown in the accompanying illustration (camshaft position A).
Install the rocker arm assemblies and tighten the rocker arm fulcrum bolts to 6-11 ft. lbs. (7-17 Nm) to position the rocker arm seats.
Rotate the crankshaft clockwise 120 degrees to camshaft position B as shown in the accompanying illustration. Tighten the rocker arm fulcrum bolts to 6-11 ft. lbs. (7-17 Nm) to position the rocker arm seats.
The fulcrums must be fully seated in the cylinder head and the pushrodsmust be seated in the rocker arm sockets prior to the final tightening.
Final tighten the rocker arm fulcrum bolts to 20-28 ft. lbs. (26-38 Nm).
If the same valve train components are used a valve train check is not required.If new components were installed, measure the clearance with the valve tappetfully collapsed on the base circle of the camshaft lobe. The measurement should be 0.085-0.185 inch (2.15-4.69mm). Refer to the accompanying illustration if necessary for the valve clearance measurement.
