Bought a car with Sync and trying to update the software. Cannot find a download link for either 4.4 or 4.6.
Anyone know where I can download either of these (preferably 4.4). Thanks.
PS- I registered at SyncMyRide but didn't see anything there...
Discussion Starter · #2 ·
Found a download for 4.6 but it won't install. I was reading that others had issues installing 4.6. Is it best to format the flash drive as FAT 32 or exFAT?
Ford says to use exFAT, but I'm thinking maybe the older Fords can't read exFAT and need FAT 32 and maybe that's why it's not installing? Any thoughts?
hi, I didn't try the 4.4 update nor 4.6 but I always had a problem when updating on ford website, the problem you face mostly are with the txt file ( I think? )
you must reconfigure it, the way is a bit tricky but you can find it
Where did you find the 4.6 download? I typically use FAT32 on electronics outside of computers.
I found it at the Ford website - SyncMyRide.com.
Ford says to format as exFat. I have tried both ways and neither seem to work. Very frustration....
