2014 Ford Taurus Limited 3.5L V6 N/A FWD
This will add factory Sync 3.4 to any
2013-2019 Ford Taurus
217698
Taurus from 2013-2015 with Factory 8" My Ford Touch (Sync 2)
You need the following
SYNC 3.0, 3.2, 3.3 or 3.4 APIM And Screen
Sync 3 compatible hub (Amazon, Ebay, or Ford Dealership)
Sync 3 compatible GPS Antenna (Amazon, Ebay)
EVENTHOUGH YOUR SYNC 3 DOSEN'T HAVE NAVIGATION!
Sync 2 to Sync 3 USB Power Adapter (GEN 1)
Usb hub bezel (Ebay)
After installation (3.0, 3.2, 3.3)
Full Tutorial on CyanLabs and on YouTube Torque And Tech Sync 3.4 Update.
cyanlabs.net/tutorials/update-ford-sync-3-2-2-3-0-to-version-3-4-all-years-3-4-19200-2/
APIM Programming with Forscan coming soon.
2016-2019 Sync versions (3.0, 3.2, 3.3)
THANKS Op!
I downloaded and installed Sync 3.4 with the Nav update this morning on my 19 Explorer. It had 3.0 with 2017 map on it.
Very simple, took 29 minutes to complete. I only had to re-add my phones and redo settings for the Nav favorites.
I like the newer Sync interface.
@4EverFord I hope your 19 Explorer is not under warranty. If it is (even if you have an extended warranty), the APIM is no longer covered due to having unauthorized software in it.
You could have download free 2019 mapping for your vehicle from the ford map website. Your wireless updating will never work now. If there is an issue with the vehicle that involves the APIM and the dealer attempts any diagnostics or software maintenance involving the SYNC APIM it will fail and they will be unable to complete it.
Hopefully you were aware of all this before you did the update.
Does your dual climate and ambient lighting if equipped work correctly via touchscreen?
The Ambient Lighting YES! Works Perfectly Fine with my setup.
218167
The Dual button works but I don’t know if it’s my version of Sync 3.4
But when the Dual Button “On Screen” is ON
the Center Stack is OFF
Same thing applies if the Dual Button on the “Center Stack” is ON
And On Screen is OFF.
218168
218169
It’s not that big of a deal breaker because Sync 3 such a good system compared to the old Sync 2 Apim and Screen.
If y’all were wondering Apple CarPlay and Android Auto both works perfectly with the Sync 3.4 Upgrade!
Apple CarPlay
218170
Android Auto
218171
