Trying to figure out where the best place for me to mount this http://cgi.ebay.com/ebaymotors/3-Toggle-Sw...%3A1|240%3A1318 switch panel to my G3. Any suggestions?
Wow your paying 25 bucks for that when you can get all three switches from radio shack for 10 bucks and just build it into your dash like so?
http://www.radioshack.com/product/index.js...oductId=2062493
Its easy, and just requires having patience to drill through the plastic.
Either way, its going to require fabrication/modification.
<div class='quotemain'>
[/b][/quote]No no i plan to build it myself but im going to fabricate it after that one. I already have the switches all i need to make is a housing
lets see you have the tec so i would asume you have a center console if you dont use your sah tray you could try there, use one of your cupholders(i have a spare set of 99 cupholders from a SHO listed in the forsale section if you want a spare around) , or could try mounting it in your console under the lid. if you do not have the console i have no idea lol
Just do this, I already had the spots cut out when I bought it, but use a dremel and its that easy.
This is why I let all my switches dangle under the dash....
