Any sway bar from a Taurus (sedan--not wagon!) will fit. Did you check to see if you even have a rear sway bar now? Some Gen 4s don't even have the rear bar (cost-cutting by Ford.) If that's the case, even a 19mm bar will help you out some. I have one in my garage, if you are interested. IMO, it would be better to pull one from a junkyard, since you would be able to get the brackets and bushings to mount the bar with it. DON'T re-use the stock Ford rear end-links. They are crap. AutoZone sells Energy Suspension endlinks for about $15 that are 10x better.
If you are just interested in upgrading the rear bar, go with a 23mm. They came on most of the Gen 2 SHOs. If you go any bigger, you will get oversteer unless you go bigger in the front too. The 24/26 front/rear combo is a favorite for the autocross guys (and girls!) Some people report that the ride is a bit too harsh when dealing with potholes and regular street driving, but that is really just a personal preference. I have a 22mm front and 25mm rear bar right now. I'm putting in a 24mm front bar this weekend, b/c in the snow and ice, the rear end of my car likes to swing out just a bit.
Here are some links for you to check out...
SHOForum classifieds
Super High Output forum classifieds.
SHO sway bar information.
And of course, check eBay frequently for deals. I was able to get my 25mm rear sway bar for about $50 on eBay. That's alot better than spending a day running around looking through junkyards.
