Hey, y'all, I took my 2002 Taurus wagon to a repair shop about a knocking in the front right. They pulled the front left wheel and showed me that the bushing is worn out. They said that they would not do the work because the part is not available from their supplier and that the mounting bracket would have to be cut and welded because it isn't attached with bolts. I called another shop and they wouldn't touch it. When I called a suspension shop they said that they couldn't look for two weeks. I called some welding shops who will look at it.
I've been reading posts about this and can't get it figured out. Some posts suggest going to the yard and getting the brackets. Others say to buy a whole sway bar. I see the items available on line but there are bars, bushings, kits, brackets with bushings, brackets with bolts and some without bolts.
Can anyone help sort this out? I sure would appreciate it. Thanks so much
