Ok, I'm sure all you long time members have already began rolling your eyes.
I just looked in the service CD to check on the stock water pump.
Why, you ask? Here is my idea...
If you look at the arrangement of the engine bay on a duratec engine, we find that the belts are on one side and the intake is on the other. As we've discussed before, this causes a problem. Hood clearence is another problem. Here is an idea though.
I've seen that you can get electronic water pumps. They run on the car's charging system rather then the belts. Race vehicles often use these as they are less parasidic in nature.
At first I shot this idea down because I thought that the water pump fed directly into the engine block. After I read the ford service CD for replacing the water pump, it sounds like it in fact has an input and an output hose and does't bolt it's output directly to the block. This means that after removing a few bolts, you can easily replace the water pump with an electric one and suddenly you have room for a centrifugal charger right there on your engine block.
You can get your air charge from the passanger side of the car and just run a tube to the MAF on the driver's side. You could even put an intercooler somewhere in the front of the car along the way to the intake.
So does anyone see problems with this?
-Dan
-Dan
-Dan
-Dan
