Hi all,
My 2003 Sable electric sunroof opens only about 1 inch, then stops moving any farther open. Afterward, it will successfully reclose. So the travel is just 1 inch.
It does open, and close, in the "pop-up" mode where the glass tilts upward and downward.
Might the problem be a limit switch, relay, other cause?
Has anyone else had, and repaired, this problem?
Thanks,
Sable 2003
If you pop off the back seat access cover above the motor...can you get someone to cycle the moonroof while you listen to the motor? Does it feel like it's stopping or slowing down? Any odd nosies?
Do you have the black plastic trim in place that prevents the sunshade from going back into the headliner when the glass is closed? The handle should be visible when the sunshade is pushed all the way back.
