Can a defective sunload sensor affect the A/C in a 2000 Sable with automatic temp control?
The A/C started blowing hot air suddenly - worked one day and not the next. There was no gradual decline. I was thinking it might be the blend door problem and was searching threads for repair suggestions and encountered several threads that relate the sunload sensor to the A/C system.
I checked for EATC codes and get only an 051 code for the sunload sensor. I checked the sensor and it is not working - lights stay on in bright sunlight. I am more concerned about the A/C than the automatic lighting - replacing the sunload sensor just to correct the lighting issue would not be a high priority.
Thank you
Thank you
I replaced the sls on my '01 from a Pick A Part yard. Easy to replace and all is well. Auto heal lamps always on and A/C not working correctly.
The sensor does 2 things at the same time. 3 wires to the combined "amplifier". Pop the defroster grille out and 2 small screws hold it in place.
^+1. A new sunload sensor should cure both your ac and autolamp ills. Click on the search feature or topic finder at the top of this page. Bull Geek (Nick) has a nice write-up (with pics) on the sunload sensor.
That stupid sensor made my AC go crazy. You'd hit the AUTO button and select a temp, and cold air would never come out. new one fixed it as well as my autolamps :)
Iirc, it's atop pass. dash. Check out member Bull Geek's (Nick) write-up with pics in the forum topic finder and/or wiki.
