How do i drop the front sub frame and what other jacks do i need for my 99 taurus wagon to get the job done, so i can put the ball joint stud back in the lower control arm.
i never had to drop the sub frame. i angle the stud towards the hole and pry down the contrrol arm then push the strut in normally falls in with a little bit a elbow grease
Assuming 99 is not different from 05, remove the plastic shield from the front bottom. Front subframe bolt will be exposed. On my 05 I had to remove the dog bone engine torque strut. Loosen the front and rear subframe bolts on one side only. No need to completely remove them. Several turns only. about 1/2 to 3/4" drop.
Agree. I never dropped a sub.
I have loosened contol arm bolts, not taken them out, and used a pipe to spring the end of the control arm. Bigger lever makes for less "elbow grease". :lol2:
Placing a jack will not hurt. You don't need to completely remove the bolts. Like many others I didn't lower the subframe for BJ job. But it will certainly make the job easier.
